95
UltraWebGrid and WebHierarchicalDataSource problem using dynamically created object
I have an UltraWebGrid which uses the WebHierarchicalDataSource to create a parent/child relationship for 2 List<> objects.   I originally was using 2 ObjectDataSources to capture what I needed and bind to the dataviews from the WebHierarchicalDataSource.  This worked fine.  However, I want to filter the objects based on certain criteria(I don't want to use the filtering mechanism in the UltraWebGrid).   So I took the ObjectDataSource controls out and decided to bind the views dynamically to the List<> objects after I filtered the lists accordingly(based on my own search mechanism).  The original grid posts fine, but when I do a postback, I get the error:
"DataView has no DataSourceID or DataSource set."
It seems that the dataview is trying to bind again after the Page_Init event.  Since I repopulate the dataviews in the click event handler, the binding is happening too soon and erroring out.  Can I get some help with this?  Thanks.
Here is the asp code, I commented out the ObjectDataSource cause I'm not using it anymore:
<Infragistics:WebHierarchicalDataSource ID="InvoiceSummaryHierarchicalDS" runat="server" >
<DataViews>
<Infragistics:DataView ID="parentView" />
<Infragistics:DataView ID="childView" />
</DataViews>
<DataRelations>
<Infragistics:DataRelation ParentColumns="GroupId" ChildColumns="GroupId" ParentDataViewID="parentView" ChildDataViewID="childView" />
</DataRelations>
</Infragistics:WebHierarchicalDataSource >
<!-- <asp:ObjectDataSource ID="objOpenInvoiceSummaryGroups" SelectMethod="GetParentInvoiceSummaries" TypeName="Module.Invoices.InvoiceSummariesPresenter" runat="server" >
<SelectParameters>
<asp:Parameter Type="Int32" Name="status" DefaultValue="1" Direction="InputOutput" />
</SelectParameters>
</asp:ObjectDataSource>
<asp:ObjectDataSource ID="objOpenInvoiceSummaryLocations" SelectMethod="GetChildInvoiceSummaries" TypeName="Module.Invoices.InvoiceSummariesPresenter" runat="server" >
<SelectParameters>
</SelectParameters>
</asp:ObjectDataSource>-->
protected void Page_Load(object sender, EventArgs e)
List
<Svc.InvoiceBillSummary> parentList = _presenter.GetParentInvoiceSummaries((int)Svc.InvoiceStatusTypeEnum.Closed);
List<Svc.InvoiceBillSummary> childList = _presenter.GetChildInvoiceSummaries((int)Svc.InvoiceStatusTypeEnum.Closed);
//filtering happens here
GetHierarchicalData(parentList, childList);
private void GetHierarchicalData(List<Svc.InvoiceBillSummary> parentList, List<Svc.InvoiceBillSummary> childList)
parentView.DataSource = parentList;
childView.DataSource = childList;
