Hi All,
I am facing some realtime issue in my implementation.
I want to implement dynamic rows and dynamic columns headers. I want to have a two dimensional matrix
matrix with dynamic row header names and column names. In the matrix then I need to put the data
checking the column header name and row name.
The data field should be editable and need to capture the changed value of the cell.
Its urgent.
Thanks and Regards
Monish
Hi Monish:
Have you looked at the grid examples at componentsforjsf.com? There are examples there for making grid cells editable - its really easy.
The easiest way to create dynamic rows and columns is to bind the grid to a different data cllection on the server. There are several techniques for this, some of which have been described in othe rposts on this forum. The basic technique is to generate the grid dynamically on the server rather than relying on JSP or XHTML code.
In your JSP you have only (something like) the following:
<ig:gridView binding="{#someBean.gridObject" id="myGrid" />
and everything else is on the server.
The classes needed for generating a grid from server-side Java code are all listed in the Infragistics API.
If you are really in a hurry you mght want to contact Infragistics and ask them about hiring a consultant to build this for you.
Best,Jim
