Trying to get going quickly with xamWebChart, just downloaded the evaluation version and I'm running SL 3.0. I'm trying to embed the chart on a TabItem, but whenever the tab it is on is not visible, I get constant (every second or so) Argument Exceptions thrown by UIElement TransformToVisual:
> System.Windows.dll!MS.Internal.XcpImports.MethodEx(System.IntPtr ptr = 152514400, string name = "TransformToVisual", MS.Internal.CValue[] cvData = {MS.Internal.CValue[1]}) + 0x1c1 bytes System.Windows.dll!MS.Internal.XcpImports.MethodPack(System.IntPtr objectPtr = 152514400, string methodName = "TransformToVisual", object[] rawData = {object[1]}) + 0xc92 bytes System.Windows.dll!MS.Internal.XcpImports.UIElement_TransformToVisual(System.Windows.UIElement element = {Infragistics.Silverlight.Chart.XamWebChart}, System.Windows.UIElement visual = {SilverlightClient.MainPage}) + 0x85 bytes System.Windows.dll!System.Windows.UIElement.TransformToVisual(System.Windows.UIElement visual = {SilverlightClient.MainPage}) + 0x2b bytes Infragistics.Silverlight.DataVisualization.v9.1!Infragistics.Silverlight.DataVisualization.TrialHelper.a.a() + 0x2d0 bytes Infragistics.Silverlight.DataVisualization.v9.1!Infragistics.Silverlight.DataVisualization.TrialHelper.a.a(object A_0 = null, System.EventArgs A_1 = {System.EventArgs}) + 0x23 bytes System.Windows.dll!System.Windows.FrameworkElement.OnLayoutUpdated(object sender = null, System.EventArgs e = {System.EventArgs}) + 0x145 bytes System.Windows.dll!MS.Internal.JoltHelper.RaiseEvent(System.IntPtr target = 0, uint eventId = 2, System.IntPtr coreEventArgs = 0, uint eventArgsTypeIndex = 0) + 0x11e bytes
"A first chance exception of type 'System.ArgumentException' occurred in System.Windows.dllAdditional information: Value does not fall within the expected range."
This even occurs if I create an empty chart and remove it immediately!:
MainPage_Loaded(..)
localChartTest = new Infragistics.Silverlight.Chart.XamWebChart(); ChartTestPanel.Children.Add(localChartTest); ChartTestPanel.Children.Clear();
(ChartTestPanel is a child of a tab item, I still get constant exceptions)
Whats going on here? I'd really like to try out your charts but I'm in a hurry...
Daniel
i also tend to use this setting, so i understand how it can be annoying when a handled exception is thrown in some other library. unfortunately, last i checked there wasn't a way to detect the condition leading to this exception. on the brighter side, this will not happen in the full version since it is part of our trial watermark rendering.
Thanks. Its still annoying though since I often want to trap exceptions from my own code that may or may not result in a cryptic error message in the web browser if I dont have the debugger catch them.
that is a first chance exception, meaning it is handled in a try/catch block. from the Debug > Exceptions menu in Visual Studio, uncheck the box that says to break on all CLR exceptions.
