I'm very new to web development and the UltraWebGrid :-) I have a very simple UltraWebGrid within an asp:wizard control. I manually add rows to the grid as the data is not coming from a database as such. All is fine so far and I have implemented my own crude form of 'move row up/down' to allow ordering. When I click on the cell which contains a button, after my server side button handler is called I receive a JavaScript error as above. I also get this same error when I simply move to the next page in the wizard so I guess it is as a result of a postback in the grid.
I have no idea what could cause this as the error appears to be coming from the grid which is as I said very simple. Any ideas are most welcome!
Ok I have not updated the dll into my project folder.After updating that the java script error is got fixed.
I have download the current service realease for infragistics 8.3.But still problem is same.Every I visit the page which has got an infragistics grid then on load and unload of page this error pop ups.
Please suggest us.This problem is really testing my temprament.I can't figure out it is an IE 8 issue or Infragistics 8.3.
We are getting the same error in infragestics 8.3 verion. Please let us know if there are any solutions.
VISHVANATHA ACHARY
Nous infosystems Pvt Ltd.
Take a look at your registry, in the following location, and you might see the following (or similar) values. Try removing the items for CLR 3.0.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\User Agent\Post Platform]
".NET CLR 1.1.4322"=""
".NET CLR 2.0.50727"=""
"InfoPath.1"=""
".NET CLR 3.0.04506.30"=""
".NET CLR 3.0.04506.648"=""
".NET CLR 3.5.21022"=""
".NET CLR 3.0.4506.2152"=""
".NET CLR 3.5.30729"=""
I came across this issue and also reported it to our development team. I'm not sure if you are referring to the recent Service Release 8.3.20083.2102 (released on July 28th) or the previously released 20083.2021(released in Dec of last year). I've tested my sample with the latest released Service Release and it's fixed.
I would recommend downloading the recent service release and testing the application. Please visit the following link on how to download and install the latest Service Release.
http://blogs.infragistics.com/blogs/vince_mcdonald/archive/2009/06/25/service-release-published-netadvantage-windows-forms-and-asp-net-june-25-2009.aspx
If the issue still persists, then please submit a support request with our Developer Support Team by visiting the following link:
http://ko.infragistics.com/support/default.aspx#Overview
Sarita
