I am trying to add a checkbox to a node in the tree. The nodes are being added to the tree from the javascript.
var loNewNode = loWebTreeNode.addChild("Node Name");
How can I enable the check box from the client side (without inserting in the innerHTML of the element). Is there anyway with out turning on the checkboxes for all nodes? I have not been able to find it. Thanks.
P.S. To clarify, the check boxes are not required for the whole tree, just the leafs. (which are not root nodes)
Well, just in case anyone is intetrested, I have found a what seems to be a hack to make this work.
Before adding the nodes that you want checkboxes on (showing for) change the master checkboxes property on the main tree object to true. When done adding, set the property back to false.
//TURN ON CHECKBOXES if childrenif (!Does not have children) igtree_getTreeById(webTreeId).CheckBoxes = true;
var loNewNode = loWebTreeNode.addChild("Name");
//turn check box off
igtree_getTreeById(webTreeId).CheckBoxes = false;
