66
ComboBox Default Value
note: the name of the field on the datatable that has the default value is "resource"
I'll try my best to explain what I'm attempting to do. I have a datatable that contains (let's say) Resource and Resource ID. Resource may or may not be populated (i.e. it could be blank). Moreover, Resource needs to be selected from a dropdown menu. Therefore, what I'm trying to do is make my grid look something like
http://samples.infragistics.com/2009.1/WebFeatureBrowser/Default.aspx
where there are no instances of the drop down maintained until the cell is clicked to enter edit mode. However, if there already is a value set for resource, I would like that value selected in the cell (without loading the actual drop down control). I can only get my table to bind to the grid as text or get the drop downs to bind without the default values showing.
How can I do this using the WebGrid? Thanks in advance! Below is the code I'm using (which binds the text correctly, but doesn't implement the drop down)
note: the name of the field on the datatable that has the value I'm looking for is "resource"
<%-- COMBO BOX -->
<igcmbo:webcombo id="ResourceCB" runat="server" Version="3.00"
            DataValueField="last_name" DataTextField="last_name"
            DataSourceID="SqlDataSource5">
                <Columns>
                    <igtbl:UltraGridColumn BaseColumnName="last_name" IsBound="True"
                        Key="last_name">
                        <header caption="last_name"></header>
                    </igtbl:UltraGridColumn>
                    <igtbl:UltraGridColumn BaseColumnName="first_name" IsBound="True"
                        Key="first_name">
                        <header caption="first_name">
                            <RowLayoutColumnInfo OriginX="1" />
                        </header>
                        <Footer>
                        </Footer>
                                    </Columns>
            </igcmbo:webcombo>
<%-- GRID -->
    <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server"
        DataSourceID="ObjectDataSource2"          >
        <Bands>
                 <igtbl:UltraGridColumn BaseColumnName="Resource" IsBound="True" Key="resource"
                        EditorControlID="ResourceCB" Type="Custom">
                        <Header Caption="Resource">
                            <RowLayoutColumnInfo OriginX="4" />
                        </Header>
                        <Footer>
                        </Footer>
