This is the code (within a click event of a button) I use to remove the active row
AssignedGrid.Rows.Remove(AssignedGrid.DisplayLayout.ActiveRow)
The grid is within an AJAX UpdatePanel. After I click the button everything else is refreshed right but now I have a blank row in the grid. Why?
Hello Bernardo,
Thank you for posting your inquiry to the Infragistics forums. I tested the behavior you described using the attached sample and was unable to reproduce this issue. The attached sample contains an UltraWebGrid with some rows in an UpdatePanel. There is a button on the page and I added the code you posted in the button click.
Please download and test the attached sample. Select a row and click the button. The row will delete without leaving a blank space. If this sample is not an exact replica of your application, please modify the sample and re-attach or post an update to let me know.Thank you.Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
