334
Fixed header while scrolling
I would like to keep the grid's header fixed while scrolling. I have tried setting StationaryMargins="Header", but didn't work. This caused all cells of the grid to be merged.
Any suggestions on how to achieve this?
  • 45049
    Suggested Answer
    This is how you keep the grid's header from scrolling when the grid is scrolled vertically.
    You also have to have set the grid's DisplayLayout.TableLayout property to "Fixed" for this to work.  This is done for you automatically if you set StationaryMargins through the designer; if you did this through code, then you need to set TableLayout through code as well.
    Assuming that this isn't resolved by setting TableLayout, can you provide a screenshot as to what you mean, or possibly a sample application?  Either way, you can attach these to your response post from the "Options" tab.
