1220
grid OutOfMemory exception while paging (clicking on a page #)
hello,
i have a basic pager configuration and experiencing some problems. When page size is 500, the grid appears to be freezing the browser.
but my main problem as of now, is that when i set the page size to 100, i get OutOfMemoryException.
here is my page configuration:
                this.DisplayLayout.Pager.AllowPaging = true;
                this.DisplayLayout.Pager.PageSize = this.PageSize.Value;
                this.DisplayLayout.Pager.Alignment = PagerAlignment.Center;
                this.DisplayLayout.Pager.PagerStyle.CssClass = "caption gridpagerlinks";
                this.DisplayLayout.Pager.PrevText = "Previous";
                this.DisplayLayout.Pager.NextText = "Next";
                this.DisplayLayout.EnableInternalRowsManagement = true;
here is the full exception i get after clicking on page #33 (out of 73). It appears that viewstate serializer fails?
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. at System.String.GetStringForStringBuilder(String value, Int32 startIndex, Int32 length, Int32 capacity) at System.Convert.ToBase64String(Byte[] inArray, Int32 offset, Int32 length, Base64FormattingOptions options) at System.Web.UI.ObjectStateFormatter.Serialize(Object stateGraph) at System.Web.UI.ObjectStateFormatter.System.Web.UI.IStateFormatter.Serialize(Object state) at System.Web.UI.Util.SerializeWithAssert(IStateFormatter formatter, Object stateGraph) at System.Web.UI.HiddenFieldPageStatePersister.Save() at System.Web.UI.Page.SavePageStateToPersistenceMedium(Object state) at System.Web.UI.Page.SaveAllState() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) ,
  • 1220
    this is an issue with viewstate deserialization. since this is a grid with 7700 rows, postback is not handling the huge grid..
    one solution i can think of is overriding viewstate handling and not dumping it into __viewstate field on the page..
    any other ideas?
