305
WebTab Progess Indicator with Server-Side Events
I've been looking at all the examples, reading all the forum posts, and trying every combination I could think of.  However, I can't find a way to get a seemingly simple concept to work.
I have an UltraWebTab inside an AJAX UpdatePanel.  Until today, I had turned all Async operations off.  I have database operations occuring in the .aspx.vb file on SelectedTabChanged.  However, I want a Progress Indicator to appear while the operations are occuring.
I tried having client-side events when the Async operations were on, but a __doPostback("<%= uwtStores.ClientID %>", ""); didn't seem to work.
What is the proper way to have both Server-Side events and the progress indicator appear?
Any help would be greatly appreciated.
Kyle
  • 24497
    Hi Kyle,
    If I understood correctly, then you try to use async features of tab located in UpdatePanel. Unfortunately that combination is not supported. UpdatePanel and UltraWebTab can not be nested in each other, because they use global callback managers which are not compatible with each other. UpdatePanel and UltraWebTab can be used only side by side.
