How can I set UltraWebmenu's right arrowhead display or no display?
do you want for the whole tree? or per item?
The most simple way to make is hide is to create an arrow image (modify the infragistics one with an image editor) and make its color the same as the menus background for that area. Set the tree to use your image and then you will not be able to see the arrow...
