I'm trying to figure out how I should handle a drag/drop operation.
The source will be a tree node and the destination will be an Infragistics WebGrid.
Can anyone suggest the way I should go about this. I'm using VB as the code-behind. However, I get the feeling I'll need to do this with JAVA script. I was reading this article which talks about ASP.NET AJAX and the 'Sys.Preview.UI._DragDropManager' class:
http://msdn.microsoft.com/en-us/magazine/cc135985.aspx
The article goes on to say, "... the ' DragDropManager ' is the glue that binds drag sources and drop targets together. Without it, you'd be writing a ton of code to make drag-and-drop user interfaces work—especially if they had to work in a variety of browsers."
Any thoughts here??
Thanks!!
