145
WebGrid - Row Selection detection
Hi There
I would like to combine the row selection in the WebGrid with the menu pop up. Is there any chance to detect and render the menu options based on the  user selection? As in before selection there may be x items in the menu and only if there is a row selected two more menu options will appear ( to view and edit that row)
For example is there a way to do something similar to the below:
<ig:menu id="popup1" popup="true" orientation="vertical">
    <ig:menuItem value="Edit This Derivative" iconUrl="/resources/blank.gif"/>
    <ig:menuItem value="Create New" />
    <ig:menuItem value="Go ElseWhere" />
 <% if (  Something.getRowSelected() != null){
         <ig:menuItem value="View This Row" "/>
         <ig:menuItem value="Edit This Row" />
         <ig:menuItem value="Delete This Row" />
</ig:menu>
Of course this means that the menue component is refreshed upon each selection
any idea?
Many thanks in advance
Shai Koren
