215
Infragistics UltraWebGrid 9.1 issue
I am using  ultrawebgrid version 9.1.20091.2055 (latest release). If any of the column of the grid is hidden and if we try to resize the header column , the column cannot be resized and gets distorted.This issue happens in IE8.
Code for aspx is:
@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.2055, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
html xmlns="http://www.w3.org/1999/xhtml" >
head id="Head1" runat="server">
<title>Untitled Page</title>
head>
body>
<form id="form1" runat="server">
<div>
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="319px" Width="569px">
<Bands>
<igtbl:UltraGridBand>
<AddNewRow View="NotSet" Visible="NotSet">
</AddNewRow>
<Columns>
<igtbl:TemplatedColumn Width="25px" Hidden="true" >
<CellTemplate>
<input type="checkbox" />
</CellTemplate>
</igtbl:TemplatedColumn>
<igtbl:TemplatedColumn Width="25px" >
<CellTemplate>
<img id="SearchMenuBtn1" alt="image" title="click to see options for the account." src="../../../Images_Global/spacer.gif" class="listing-arrow" onclick="PopControl(this,SearchMenuDiv,'right');" />
</CellTemplate>
<Header>
<RowLayoutColumnInfo OriginX="1" />
</Header>
<Footer>
</Footer>
</Columns>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowDeleteDefault="Yes"
AllowSortingDefault="OnClient" AllowUpdateDefault="Yes" BorderCollapseDefault="Separate"
HeaderClickActionDefault="SortMulti" Name="UltraWebGrid1" RowHeightDefault="20px"
RowSelectorsDefault="No" SelectTypeRowDefault="Extended" StationaryMargins="Header"
StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version="4.00" ViewType="OutlookGroupBy">
<FrameStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
BorderWidth="1px" Font-Names="Microsoft Sans Serif" Font-Size="8.25pt" Height="319px"
Width="569px">
</FrameStyle>
<Pager MinimumPagesForDisplay="2">
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
</PagerStyle>
</Pager>
<EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
</EditCellStyleDefault>
<FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
</FooterStyleDefault>
<HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid" HorizontalAlign="Left">
</HeaderStyleDefault>
<RowStyleDefault BackColor="Window" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
Font-Names="Microsoft Sans Serif" Font-Size="8.25pt">
<Padding Left="3px" />
<BorderDetails ColorLeft="Window" ColorTop="Window" />
</RowStyleDefault>
<GroupByRowStyleDefault BackColor="Control" BorderColor="Window">
</GroupByRowStyleDefault>
<GroupByBox>
<BoxStyle BackColor="ActiveBorder" BorderColor="Window">
</BoxStyle>
</GroupByBox>
<AddNewBox Hidden="False">
<BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth="1px">
</BoxStyle>
</AddNewBox>
<ActivationObject BorderColor="" BorderWidth="">
</ActivationObject>
<FilterOptionsDefault>
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
Font-Size="11px" Height="300px" Width="200px">
<Padding Left="2px" />
</FilterDropDownStyle>
<FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
</FilterHighlightRowStyle>
<FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
Font-Size="11px">
</FilterOperandDropDownStyle>
</FilterOptionsDefault>
</DisplayLayout>
</igtbl:UltraWebGrid></div>
</form>
body>
html>
code for cs file is
protected void Page_Load(object sender, EventArgs
e)
DataSet ds1 = new DataSet
DataTable dt1 = new DataTable
ds1.Tables.Add(dt1);
string columnStartName = "Column"
string
columnName;
for (int
i = 0; i < 10; i++)
if
(i < 10)
columnName = columnStartName +
"0"
+ i.ToString();
else
columnName = columnStartName + i.ToString();
ds1.Tables[0].Columns.Add(columnName,
typeof(string
for (int
j = 0; j < 20; j++)
DataRow
dr1 = ds1.Tables[0].NewRow();
for (int
i = 0; i < 10; i++)
if
(i < 10)
"0"
+ i.ToString();
else
dr1[columnName] =
"ABCDEF"
ds1.Tables[0].Rows.Add(dr1);
UltraWebGrid1.DataSource = ds1.Tables[0];
UltraWebGrid1.DataBind();
-Arati.
