The Back and Forward arrows are not displaying for the WebDateChoosers deployed on a new production application. Everything works fine on the development and test servers, but not the production server. Any suggestions?
Thanks in advance.
HI FireStorm12,
There is a property called CalendarLayout=>ShowNextPrevMonth - if it is set to false then you will not see the arrows, If its set to true you will .
Also check to see if you set the CalendarLayout=>PrevMonthImageUrl and NextMonthImageUrl. - these properties allow you to customize the arrow images. Make sure that these images are on the server and in the right driectory
