90
Client Side javascipt on cellButtonClicked
Hi i have an updatePanel (Ajax)  and inside a ultrawebgrid with two columns as buttons delete.update
On the clientside events i added a function to ask the user do you want to delete and then calls the server side code to actually delete the row the javscript  function is
function
alert(gridName, cellId){
var grid=igtbl_getGridById('<%= documents_grid.ClientID %>');
var cell=igtbl_getCellById(cellId);
if (cell.Column.Key=='Delete'
var c=confirm("‘Do you want to delete");
if (c){
igtbl_doPostBack(gridName);
else {
igtbl_cancelPostBack(gridName)
the problem is the postBack never occurs. The updatepanel is in conditional mode asynchronous for the two buttons.When i remove the clienteventhadling all works ok.
Any ideas
Thanks in advance
