60
How to validate WebEditor through javascript
hi!
   I want to validate if WebEditor is null or not having any text please help me.
  • 24497
    If you are interested in changes, then it is better to process ClientSideEvents.ValueChange/TextChanged/InvalidValue. If you need a current value in editor, then you may use getValue(), getText() and other more specific member functions for a specific editor. Please consult CSOM docs for editors. Below an example:
    <igtxt:WebNumericEdit ID="WebNumericEdit1" runat="server"></igtxt:WebNumericEdit>
    <igtxt:WebMaskEdit ID="WebMaskEdit1" runat="server" InputMask="(###)###-####" DataMode="RawText"></igtxt:WebMaskEdit>
    function checkVal()
    var str = '';
    var num = igedit_getById('WebNumericEdit1');
    if(num)
         str +=
    "Numeric value='" + num.getValue() + "'\n";
    var mask = igedit_getById('WebMaskEdit1');
    if(mask)
         str +=
    "Text in maskedit='" + mask.getValue() + "'";
      window.alert(str);
    </script>
    <input type="button" value="check values" onclick="checkVal()" />
    Viktor
    Infragistics web team
