Is there any thing I can do to control the resize performance of a chart? Maybe something to make it delay redrawing a little as its container size is changed so it doesn't re-render so often?
Below is a simple repro using the new XamWebDialogWindow. If you resize the window with the text it's very responsive. When you resize the chart window, it is slow to respond. Obviously it has more to do than the text, but I was just wondering if there was anything I could tweak to make it a little more responsive. I'll set min width/height to eliminate the redraw when it gets too small, but the sizing up would still be an issue.
Thanks in advance for any ideas,Keith
<igDialogWindow:XamWebDialogWindow StartupPosition="Manual" Top="20" Left="20" Height="200" Width="200" Content="Simple text test"></igDialogWindow:XamWebDialogWindow><igDialogWindow:XamWebDialogWindow StartupPosition="Manual" Top="250" Left="150" Height="400" Width="400"> <igDialogWindow:XamWebDialogWindow.Content> <igChart:XamWebChart> <igChart:XamWebChart.Series> <igChart:Series ChartType="Pie" Label="Series 1"> <igChart:Series.DataPoints> <igChart:DataPoint Value="10" Label="point1" /> <igChart:DataPoint Value="20" Label="point2" /> <igChart:DataPoint Value="30" Label="point3" /> </igChart:Series.DataPoints> </igChart:Series> </igChart:XamWebChart.Series> </igChart:XamWebChart> </igDialogWindow:XamWebDialogWindow.Content></igDialogWindow:XamWebDialogWindow>
OK, thanks David, that's the kind of tip I was looking for. I'll give it a shot.
you could try setting RefreshEnabled to False and then invoking the Refresh() method using a timer triggered by the resize event. That way you could at least limit the number of refreshes when the user resizes the control.
