I've added icons to menu items, at design time they are visible, at runtime -- nothing. Below is the xaml any ideas?
<igMenu:XamWebMenuItem> <igMenu:XamWebMenuItem.HeaderTemplate> <DataTemplate> <StackPanel Orientation="Horizontal"> <Image Source="Images/edit.png" /> <TextBlock Text="Edit Wire" VerticalAlignment="Center" HorizontalAlignment="Center" Margin="5"/> </StackPanel> </DataTemplate> </igMenu:XamWebMenuItem.HeaderTemplate> </igMenu:XamWebMenuItem>
I got it to work, just a pathing issue as it turns out. The Source should be "/<AppName>;components/images/edit.png" now it works just fine.
Brad
Try hooking up the ImageFailed event on the Image object to see if it can help you first figure out of the image is loading sucessfully. I have found that getting paths to work in Silverlight can be a bit challenging.
Devin
