I've turned on paging in my WebGrid. I've got a templated column in my grid that is used to display a hyperlink. When move to the next page, I get the following error:
Databinding methods such as Eval(), XPath(), and Bind() can only be used in the context of a databound control.
HTML: <igtbl:TemplatedColumn BaseColumnName="ID" Key="ID"> <Header Caption="ID"> </Header> <CellTemplate> <a href="WorkOrder.aspx?WorkOrderID=<%# Eval("ID") %>"><%# Eval("ID") %></a> </CellTemplate> </igtbl:TemplatedColumn>
How would one have a template column and paging work at the same time?
Rick
Oh, great find, thanks for sharing. So I guess, UltraWebGrid behaves a little bit differently than the asp:GridView control when using templated columns, so Container.Cell is a good starting point, plus you get all the extra functionality for Row, etc.
By the way, if you are not completely sure which properties/objects are available in your template databinding expressions, you can map values using server-side methods, for example:
<igtbl:templatedcolumn isbound="True" basecolumnname="Name" key="Name"> <CellTemplate> <asp:Label runat="server" ID="Label1" Text='<%# MapStuff(Container) %>'></asp:Label> </CellTemplate></igtbl:templatedcolumn>
public string MapStuff(Infragistics.WebUI.UltraWebGrid.CellItem cellItem) { // return string depending on custom logic }
This way, you can use the VS 2005/2008 Autocomplete functionality and see all available information for the Container using the VS debugger.
I try to bind the XmlDataSource to a standart asp:GridView and it's working corect.
I made a test project to try grid binding, it isn't my real project, so I also can put the whole project code.
This is the xml file:
<?xml version="1.0" encoding="utf-8" ?><Animals> <Animal Name="Doc" Color="Gray" /> <Animal Name="Cat" Color="Brown" /> <Animal Name="Bird" Color="Blue" /> <Animal Name="Crocodile" Color="Green" /></Animals>
I solve my problem with the binding with this code:
<ig:TemplatedColumn IsBound="True" BaseColumnName="Name" Key="Name"> <CellTemplate> <asp:Label runat="server" ID="lblName" Text='<%# Container.Cell.Text %>'></asp:Label> </CellTemplate> </ig:TemplatedColumn>
You can also use
<%# Container.Cell.Row.Cells.FromKey("column2").Value >
to get the value from other column.
Hello Iva,
Thanks for writing. I guess, it really depends on the structure of your DataSource. Judging from your aspx markup, you are binding to an XmlDataSource. Could you please paste a small sample of your Xml datasource here, maybe this will provide some clues? Also, can you please try binding a standard asp:GridView control with templated columns to the same datasource and see how it goes?
I have tried something very simple (declarative flat AccessDataSource control + templated columns) and everything worked fine in my case - here is my setup:
<igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" DataSourceID="AccessDataSource1" Height="200px" Width="325px"> <Bands> <igtbl:UltraGridBand> <Columns> <igtbl:TemplatedColumn> <CellTemplate> <asp:Label ID="lblName" runat="server" Text='<%# Eval("ProductName", "Your name: {0}") %>'></asp:Label> </CellTemplate> </igtbl:TemplatedColumn> ... </Columns>...
Hello Rick,
I was able to reproduce the same problem locally. It seems that if you are manually binding the grid (e.g. not using declarative datasources), you need to bind the grid very early in the page life-cycle in order to avoid the exception you are getting - you need to re-bind the grid in the Page_Init (OnInit event of the Page) event handler.
Moving my binding code to OnInit solved the problem in my case, hopefully this approach is applicable in your case as well.
I have general problem with the TemplatedColumns.
Here is my markup for UltraWebGrid, I want to bind the value for the Name key into a Label and it doesn't work, it doesn't display anything.
<ig:UltraWebGrid ID="UltraWebGrid1" runat="server" DataSourceID="xmlDSAnimals" Height="200px" Width="325px"> <Bands> <ig:UltraGridBand AddButtonCaption="Animal" BaseTableName="Animal" Key="Animal"> <Columns> <ig:TemplatedColumn IsBound="True" BaseColumnName="Name" Key="Name"> <Header Caption="Name" /> <CellTemplate> <asp:Label ID="lblName" runat="server" Text='<%# Eval("Name", "Your name: {0}") %>'></asp:Label> </CellTemplate> </ig:TemplatedColumn> </Columns> </ig:UltraGridBand> </Bands> </ig:UltraWebGrid>
