Hi
I have a scenario like this
I have a user control in a form ,inside user control
left side UltrawebTreeView control ,Right side UltrawebTab where each tab contains one user control
When I click a node in treeview control , I basically need to refresh the contents of the Tab control.
So When I does this ,the whole page is getting refreshed.
In order to achieve ajax ,I have kept WARP around treeview and the untraweb tab.
So here the issue is ,
As every tab is one user control and each user control has it's own form level validaitons to perform.
like when I click a button called Add ,it will validate all required fields.
But when I use WARP ,the javacripts which are responsible for the validaitons doesn't get fired.
Can any one suggest me how I can make all my scripts working even with WARP?
