Have a webcombo using a SqlDataSource (in the *.aspx - not using InitializeDataSource or binding from C#)
ComboTypeAhead="Suggest"
DataValueField="Version"
The stored procedure used by the webcombo returns Version with data type = FLOAT
When I type something in the webcombo, it does not filter based on the typed value.
Then when I click a button. I get the error (details below - please advise)
Cannot perform 'Like' operation on System.Double and System.String. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.EvaluateException: Cannot perform 'Like' operation on System.Double and System.String.Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [EvaluateException: Cannot perform 'Like' operation on System.Double and System.String.] System.Data.BinaryNode.SetTypeMismatchError(Int32 op, Type left, Type right) +21 System.Data.LikeNode.Eval(DataRow row, DataRowVersion version) +451 System.Data.DataExpression.Invoke(DataRow row, DataRowVersion version) +81 System.Data.Index.AcceptRecord(Int32 record, IFilter filter) +103 System.Data.Index.InitRecords(IFilter filter) +214 System.Data.Index..ctor(DataTable table, Int32[] ndexDesc, IndexField[] indexFields, Comparison`1 comparison, DataViewRowState recordStates, IFilter rowFilter) +414 System.Data.DataTable.GetIndex(IndexField[] indexDesc, DataViewRowState recordStates, IFilter rowFilter) +240 System.Data.DataView.UpdateIndex(Boolean force, Boolean fireEvent) +165 System.Data.DataView.UpdateIndex(Boolean force) +12 System.Data.DataView.SetIndex2(String newSort, DataViewRowState newRowStates, IFilter newRowFilter, Boolean fireEvent) +113 System.Data.DataView.SetIndex(String newSort, DataViewRowState newRowStates, IFilter newRowFilter) +17 System.Data.DataView.set_RowFilter(String value) +170 Infragistics.WebUI.UltraWebGrid.DBBinding.ProcessDataViewForFillRows(DataView dataView, RowsCollection rows) +570 Infragistics.WebUI.UltraWebGrid.DBBinding.FillRows(UltraWebGrid grid, RowsCollection rows, IEnumerable datasource) +303 Infragistics.WebUI.UltraWebGrid.DBBinding.BindList(IEnumerable datasource) +3012 Infragistics.WebUI.UltraWebGrid.DBBinding.DataBind(Object dataSource, String dataMember) +2050 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.DataSourceViewSelectCallBack(IEnumerable dataSource) +131 System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +31 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.DataBind() +1429 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.LoadPostData(String postDataKey, NameValueCollection values) +5515 System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) +693 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1743 --------------------------------------------------------------------------------Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
Hi ,
WebCombo Filter only for string data type only, so you must change the query like as " select convert(id,varchar) id from emp" and you also return the procdeure as string.
Kannan.S
