595
DataBinding to WCF
My situation is that I have a user control inside the group header template of the outlook bar.  This user control has a bunch of controls that it manages as well.  The outlook bar is bounded to a wcf service and passes a value to the user control, the user control then uses that value and gets it's own values from the wcf service.  The issue I'm having is which ever group header I select first all the other group content is the same as that one. Here the test I used to get this issue:
WCF Service:
[OperationContract]
public List<GroupHeader> GetGroups()
 List<GroupHeader> groups = new List<GroupHeader>();
 for (int i = 0; i < 10; i++)
  groups.Add(new GroupHeader() { ID = i, Name = "Group " + i.ToString() });
 return groups;
[OperationContract]
public List<GroupItem> GetItems(int groupID)
 List<GroupItem> items = new List<GroupItem>();
  if (i == groupID)
   for (int j = 0; j < 15; j++)
    items.Add(new GroupItem() { ID = j, Name = "Group " + i.ToString() + " - Item " + j.ToString() });
   break;
 return items;
[DataContract]
public class GroupHeader
 [DataMember]
 public int ID { get; set; }
 [DataMember]
 public string Name { get; set; }
[DataContract]
public class GroupItem
 [DataMember]
 [DataMember]
Main Outlook bar Control Xaml:
<igOB:XamWebOutlookBar x:Name="MainOutlookBar" Width="300" Height="500">
 <igOB:XamWebOutlookBar.GroupHeaderTemplate>
  <DataTemplate>
   <TextBlock Text="{Binding Path=Name}"></TextBlock>
  </DataTemplate>
 </igOB:XamWebOutlookBar.GroupHeaderTemplate>
 <igOB:XamWebOutlookBar.GroupContentTemplate>
  <DataTemplate>
   <medscc:GroupItem GroupID="{Binding Path=ID}" />
  </DataTemplate>
 </igOB:XamWebOutlookBar.GroupContentTemplate>
</igOB:XamWebOutlookBar>
Main Outlook bar Control Code Behind:
public MainOutlookBar()
 ServiceClient.GetGroupsCompleted += new EventHandler<GetGroupsCompletedEventArgs>(ServiceClient_GetGroupsCompleted);
 InitializeComponent();
 ServiceClient.GetGroupsAsync();
void ServiceClient_GetGroupsCompleted(object sender, GetGroupsCompletedEventArgs e)
 if (e.Error == null)
  MainOutlookBar.GroupsSource = e.Result;
User Control Xaml:
 <ListBox x:Name="GroupItems">
 <ListBox.ItemTemplate>
  <DataTemplate>
   <TextBlock Text="{Binding Name}"></TextBlock>
  </DataTemplate>
 </ListBox.ItemTemplate>
</ListBox>
User control Code behind:
#region Private Members
private ServiceClient ServiceClient;
#endregion
public static readonly DependencyProperty GroupProperty =
 DependencyProperty.Register("GroupID",
 typeof(int),
 typeof(GroupItem),
 new PropertyMetadata(new PropertyChangedCallback(OnPropertyChanged)));
public int GroupID
 get { return (int)GetValue(GroupProperty); }
 set
  SetValue(GroupProperty, value);
  ServiceClientt = new ServiceClient();
  ServiceClient.GetItemsCompleted += new EventHandler<GetItemsCompletedEventArgs>(ServiceClient_GetItemsCompleted);
  ServiceClient.GetItemsAsync(value);
public GroupItem()
void ServiceClient_GetItemsCompleted(object sender, GetItemsCompletedEventArgs e)
  GroupItems.ItemsSource = e.Result;
public static void OnPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
 GroupItem groupItem = (GroupItem)d;
 groupItem.GroupID = (int)e.NewValue;
