270
Postback issue for dynamic tabs.
Currently I am using trial version of Ultawebtab doing some testing for our requirement. But I am facing an issue.
first let me explain my requirement clearly. When user click on any aspx page link that has to create a new webtab dynamically.
I able to create tabs dynmically with targeturl, but the previous pages are loosing content when I add a new tab.
how should I maintain previous content?, please help me....below is my sample code.
Ex: default page has one textbox, button and ultratab. button event fires & creates new tab with target url based on textbox value.
form0.aspx & form1.aspx are simple forms have one textbox.
TEST Scenario: step1: type 0 in main textbox click on button & type some content in form0 textbox(it would be first tab)
step2: type1 in main text box then click on button. NOW FIRST TAB WILL LOST PREVIOUS VALUE - I NEED TO MAINTAIN IT EITHER VIEWSTATE OR ANY ALTERNATE WAY.
Default.aspx:
<form id="form1" runat="server">
 <div><asp:ScriptManager ID="sdf" runat="server"></asp:ScriptManager>
<asp:UpdatePanel ID="upd" runat="server"><ContentTemplate>
<table><tr><td width="100%">
<asp:TextBox ID="txt" runat="server" />
<asp:Button ID="btn" runat="server" OnClick="btn_Click" Text="Create" />
<igtab:UltraWebTab LoadAllTargetUrls="false" ID="UltraWebTab1" AsyncMode="On" Height=500 runat
="server" BorderWidth="1px" Width="100%" BorderStyle="Solid">
<ClientSideEvents BeforeAsyncSubmit="UltraWebTab1_BeforeAsyncSubmit" />
</igtab:UltraWebTab>
</td></tr></table>
</ContentTemplate></asp:UpdatePanel>
</div>
</form>
Default.aspx.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using Infragistics.WebUI.Design;
using Infragistics.WebUI.WebControls;
using Infragistics.WebUI.UltraWebTab;
public partial class _Default : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
    protected void btn_Click(object sender, EventArgs e)
        Tabs tbs = new Tabs();
        if (txt.Text == "0")
            Tab t = new Tab();
            t.Text = "form0.aspx";
            t.ContentPane.TargetUrl = "form0.aspx";
            UltraWebTab1.Tabs.Add(t);
        else if (txt.Text == "1")
            Tab t = new Tab();
            t.Text = "form1.aspx";
            t.ContentPane.TargetUrl = "form1.aspx";
Form0.aspx & Form1:aspx:
<form id="form1" runat="server"><div>form0<asp:TextBox ID="txt" runat="server"></asp:TextBox>
</div> </form>
Thanks in Advance
Vijay.
