I use cellClicked event exactly as the on-line demo (CSOM) example. In my event hanlder zap():
function zap(sender, args)
var cell = new IgGridCell(args.get_browserEvent().target);var line = cell.getRowIndex();}
I need the cell's row index (line). The function zap() is called when user click on any cell in the grid.
But if user click on the text in a cell,
var line = cell.getrowIndex()
will throw exception, because the cell object doesn't have the function getrowIndex().
If user click on any where outside the text. The function will work, you can get the row index.
The column is defined as:
<ig:column sortBy="lastName"> <h:outputText value="#{DATA_ROW.LastName}"></h:outputText> <f:facet name="header"> <h:outputText value="Last Name"></h:outputText> </f:facet> </ig:column>
just like the excample in the demo.
I have tested a couple of days and cannot find way around it.
I think the "args" passed into zap() function is different depending where you click in a cell.
I have NetAdvantage 9.0 installed. I don't know why I don't see the same problem in your on-line demo.
I also download and installed the examples came with the NetAdvantage, and I cannot get the same
function work.
Please help.
Yan
Hey,
I am facing a similar problem as in the thread. Is there a solution found yet for this. Please revert back as soon as possible.
Hello yzbythesea,
Thank you for the detailed information. Our DS team shall open a case for this issue and shall reply back to you.
Sincerely,
Swetha
