I have a situation in which I have 3 tabs each with a grid control. Each tab would have different data loaded in the grid. Rather than putting a seperate grid on each tab, I was looking for a way to have a single grid and just load different data as the tab changes. This would be similar to the Microsoft TabStrip control if I remember correctly. Any thoughts?
Frank, this saved me a lot of time. I did just what you did and just filtered the grid based on the tab click. It works great.
Thanks for the response. I actually solved my problem by setting the height of the tab control to zero pixels and placing a table containing the grid below it with a border on the left, right, and bottom. In the tab click event, I simply load the appropriate data into the grid. This functions similar to the Microsoft tab strip control.
Hi Frank,
UltraWebTab uses separate content for every tab. So, it can not be used to keep same content for different tabs.
