100
OnInitializeDataSource and DataBind
I have a situation where I need to do both of these but I'm having problems with it.  I'm using LoadOnDemand=XML so I need OnInitializeDataSource.
I have a button whose server side event changes some data, but since the OnInitializeDataSource event fires before the button's event the data that's sent to the client is already old.  So what I tried to do was set the datasource property and call DataBind.  What ends up happening is I get blank columns where the data normally is.  I also tried calling OnInitializeDataSource instead of DataBind but the data was still old.
 How can I get it to do what I want?
void MyGrid_InitializeDataSource(object sender, Infragistics.WebUI.UltraWebGrid.UltraGridEventArgs e)
MyGrid.DataSource = GetData();
private void btnAdd_ServerClick(object sender, System.EventArgs e)
// Change the data
RenameItems();
MyGrid.DataBind();
  • 100
    Verified Answer
    Figured out my problem.
    I can call ResetRows() before setting the DataSource and calling DataBind() and everything seems to work as expected.  If there's a better way please let me know!
    // Change the data
    RenameItems();
    MyGrid.ResetRows();
    MyGrid.DataBind();
