379
Setting WebGrid height equal to document height
Hi!
    We're using Infragistics WebGrid (v. 9.1) in our project. We need to set the height of the WebGrid so as it fits in the page according to the resolution, e.g., if the screen resolution is 1024x768, then the Grid's height should fit in the page and no scrollbar should appear on the page and if the screen resolution is changed to 1280x1024, then the WebGrid's height changes accordingly to fit in the page. We were unable to find a solution to this. Please suggest how to achieve this.
Thanks & Regards
Anuj
  • 110
    Suggested Answer
    Add this CSS on your webpage.. Then drop a grid with 100% height/width and you're set.
    html
        margin:0;
        padding:0;
        height:100%; /* this is the key! */
        overflow:hidden /* No Scroll Bars */
    body
        margin:0;
        padding:0;
        height:100%;
        font-family:Arial;
        font-size:8pt;
        overflow:hidden;
    Note: There may be a bug you might notice, it is with IE7 and IE8. When 100% height using DOCType reference which SHOULD be used, the height sometimes extends somewhat heigher than what it should. Check out my post to see what I mean,
     http://community.infragistics.com/forums/p/31243/180537.aspx#180537
  • 65
    did you find a solution ? Hen
