We're using a grid where we display a "due date," which if not specifically set, displays a "default" (1/1/2000, I think). Is there a way to trick the grid into treating this date as "null" for display purposes (so that it will not display)?
The code method is the best approach available. There is no property on WebGrid that will do this automatically.
The Boss responded, "Yes, but that is the code method...was hoping to be able to do it with a format or property in the control markup." This possible?
One way is you use InitializeRow Event.
protected void UltraWebGrid1_InitializeRow1(object sender, Infragistics.WebUI.UltraWebGrid.RowEventArgs e)
if(e.Row.Cells.FromKey("ColumnName").Text == "1/1/2000")
e.Row.Cells.FromKey("ColumnName").Text = "";
