300
Sample code for "Add and Image using Map Elements"
I have several questions on this one:
1.  Again, I can't get the example code to work.  I know about that problem with the order of the worldrect code and fixed that.  But I am not seeing an image show up.
2.  I don't understand the mapping between the value property in the element and the data template in the XAML.  Is there a way to add and delete an image using only C#?  I would like to dynamically add and delete images at high speed on the fly.
thanks,
Roger
  • 28496
    Suggested Answer
    it worked okay for me.  did you copy a file called pizza.png to your ClientBin folder?  i have attached the sample project i used, perhaps it will work for you...
    The Value property can be displayed anywhere in the ValueTemplate, e.g.
    <DataTemplate>
       <TextBlock Text="{Binding Value}" />
    </DataTemplate>
    in order for the ValueTemplate to be displayed, a value must be set on each MapElement.
    unfortunately not at this time; at least not through the map's API.
    SilverlightApplication51.zip
