I'm using the StationaryMargins property on the UltraWebGrid under the <DisplayLayout> and I set it to "Header". When I view the grid now, the header stays fixed as expected, but there is significant spacing after the header and before the footer (even more there) where I have my scrollbar and page numbering. I noticed that by using IE 8 Developer Tools and checking the style sheet properties, I believe that Infragistics classes are putting some extra padding in the table tags.... Is there some other property I need to set to adjust for margins or padding or height or width?
