Good Day all ,
i have a Challenge here. Let me Explain Clearly. I have an HTML Table that gets Generated based on the Values that comes from a Database and it looks like this
you can view it with big length here
http://www.vuyiswamaseko.com/BlockGrid.JPG
now as you can see the pink Part has values when you mouse over the black arrows. So this means there are Values under nearth each other and in the WEb its Fine but when it comes to Printing this is not because some other values will be hidden. Now The Data you see here , including the Hidden Data is represented in a normal grid like this
http://www.vuyiswamaseko.com/GridFromDB.JPG
This includes the Hidden Data that comes up when you mouse Over. My challenge is that i want to Print a PDF like this
but if there are Fields behind, it must put them under neath each other in Blocks of the same Color. I have an Example of other Data. See how it Looks
http://www.vuyiswamaseko.com/Blocks.JPG
As you can see the others are Blocked Well with Colors, now and Purple long Block has Values underneath each other, so i would like to put it as a Blocks below each other with the same Color
and this is a Function that does this Blocks
public void DisplayActivities() { try { grdTimetable.DataBind(); // refresh the list of data in the grid // parse the rows in the grid, modifying the cells in the graphic table for each entry Label[] lblActv = new Label[grdTimetable.Rows.Count]; int top, left, height, id, duration; int day, sess; double hue; string colorstr, bordercolor, code, staff, venue, term, staffterm; ListItem item = new ListItem(); int[,] Mailbox = new int[timetable.Rows.Length, timetable.Columns.Length]; Menu[,] MailboxList = new Menu[timetable.Rows.Length, timetable.Columns.Length]; List<int> modls = new List<int>(); for (int i = 0; i < grdTimetable.Rows.Count; i++) { if (!(modls.Contains(Convert.ToInt32(grdTimetable.Rows[i].Cells[14].Text)))) { modls.Add(Convert.ToInt32(grdTimetable.Rows[i].Cells[14].Text)); } } modls.Sort(); for (int i = 0; i < grdTimetable.Rows.Count; i++) { day = Convert.ToInt32(grdTimetable.Rows[i].Cells[0].Text); sess = Convert.ToInt32(grdTimetable.Rows[i].Cells[1].Text); code = grdTimetable.Rows[i].Cells[2].Text + " " + grdTimetable.Rows[i].Cells[4].Text + " " + grdTimetable.Rows[i].Cells[6].Text + " [" + grdTimetable.Rows[i].Cells[7].Text + "]"; staff = grdTimetable.Rows[i].Cells[13].Text; venue = grdTimetable.Rows[i].Cells[11].Text; duration = Convert.ToInt32(grdTimetable.Rows[i].Cells[9].Text); term = grdTimetable.Rows[i].Cells[15].Text; staffterm = grdTimetable.Rows[i].Cells[16].Text; if (staffterm.Trim() == string.Empty) { staffterm = term; } lblActv[i] = new Label(); lblActv[i].Text = code + "<BR>" + staff + "<BR>" + venue + "<br>" + term; lblActv[i].ToolTip = code.Trim() + " | " + staff.Trim() + " | " + venue.Trim() + " | " + staffterm.Trim() + "\n"; lblActv[i].CssClass = "ActivityBox"; //keep track of how many subjects lie in each mailbox for (int j = 0; j < duration; j++) { Mailbox[(sess - 1) + j, day - 1]++; if (Mailbox[(sess - 1) + j, day - 1] > 1) { MenuItem m = new MenuItem(code.Trim() + "/" + Convert.ToString(j + 1) + " | " + staff.Trim() + " | " + venue.Trim() + " | " + staffterm.Trim() + "\n"); MailboxList[(sess - 1) + j, day - 1].Items[0].ChildItems.Add(m); } else { MenuItem m = new MenuItem(""); MailboxList[(sess - 1) + j, day - 1] = new Menu(); MailboxList[(sess - 1) + j, day - 1].CssClass = "MultipleSessionBox"; MailboxList[(sess - 1) + j, day - 1].Font.Name = "Verdana"; MailboxList[(sess - 1) + j, day - 1].Font.Size = FontUnit.Point(8); MailboxList[(sess - 1) + j, day - 1].Items.Add(m); MailboxList[(sess - 1) + j, day - 1].Items[0].ChildItems.Add(new MenuItem(code.Trim() + "/" + Convert.ToString(j + 1) + " | " + staff.Trim() + " | " + venue.Trim() + " | " + staffterm.Trim() + "\n")); } } // set the position top = (sess - 1) * BoxHeight; // sessions and days start at 1 left = (day - 1) * BoxWidth; int place = 0; id = Convert.ToInt32(grdTimetable.Rows[i].Cells[14].Text); for (int k = 0; k < modls.Count; k++) { if (id == Convert.ToInt32(modls[k])) { place = k; } } hue = (place * 360) / modls.Count; colorstr = CommonFunctions.HSVtoRGB(hue, 0.07, 1.0); // 0.2 hsv bordercolor = CommonFunctions.HSVtoRGB(hue, 1.0, 1.0); // 1.0 bordercolor = HSVtoRGB( hue, 0.7, 0.95 ); height = (duration * BoxHeight); lblActv[i].Attributes.Add("style", "height:" + height.ToString() + ";position:absolute;left:" + left.ToString() + ";top:" + top.ToString() + ";background-color:" + colorstr + ";border-color:" + bordercolor + ";border-width:3px"); panelActivities.Controls.Add(lblActv[i]); } for (int i = 0; i < timetable.Rows.Length; i++) { for (int j = 0; j < timetable.Columns.Length; j++) { // if there are more than 1 entries in a mailbox then visually indicate that there are multiple subjects in a cel if (Mailbox[i, j] > 1) { panelActivities.Controls.Add(drawMultipleIndicator(i, j, MailboxList[i, j])); } } } } catch (ApplicationException ex) { lblmessage.Visible = true; lblmessage.Text = ex.Message; } }
Am using UltraWebGridDocumentExporter to convert to PDF.
Thank you
