510
Editor Controls getting lost when rebinding the grid
I am using ultrawebgrid in my pages. I am specifying the EditorControl by setting EditorControlID in the InitializeLayout event of the grid. This works fine if I don't have paging or if I am not rebinding the grid. When I enable the paging, the EditorControl works fine in the first page. But when we move to the next page, the EditorControl get's lost. The same is the case when I rebind the grid (as I did in paging). I am giving you the sample code below. Can anyone please help me in resolving this?
protected void Page_Load(object sender, EventArgs e)
        if (!IsPostBack)
          InitializePage();
private void InitializePage()
 PopulateReportingPeriodTasksGrid();
 Infragistics.WebUI.UltraWebGrid.UltraWebGrid comboGrid = (Infragistics.WebUI.UltraWebGrid.UltraWebGrid)StatusCombo.Controls[0];
 comboGrid.DisplayLayout.AllowAddNewDefault = Infragistics.WebUI.UltraWebGrid.AllowAddNew.Yes;
 comboGrid.DisplayLayout.AllowUpdateDefault = Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes;
private void PopulateReportingPeriodTasksGrid()
 DataSet ds = new DataSet();
 ds.Clear();
 ds = DataService.ListReportingPeriodTask(UserIdentity, (int)TaskStatus.Status.Open);
 if (ds != null)
     ReportingPeriodTasksGrid.DataSource = ds.Tables[0].DefaultView;
     ReportingPeriodTasksGrid.DataBind();
protected void ReportingPeriodTasksGrid_InitializeLayout(object sender, Infragistics.WebUI.UltraWebGrid.LayoutEventArgs e)
 e.Layout.Bands[0].Columns.FromKey("TaskStatus").Header.Caption = "Status";
        e.Layout.Bands[0].Columns.FromKey("TaskStatus").Type = Infragistics.WebUI.UltraWebGrid.ColumnType.Custom;
        e.Layout.Bands[0].Columns.FromKey("TaskStatus").EditorControlID = "StatusCombo";
        e.Layout.Bands[0].Columns.FromKey("TaskStatus").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes;
        e.Layout.Pager.AllowPaging = true;
        e.Layout.Pager.PageSize = 25;
protected void ReportingPeriodTasksGrid_PageIndexChanged(object sender, Infragistics.WebUI.UltraWebGrid.PageEventArgs e)
 this.ReportingPeriodTasksGrid.DisplayLayout.Pager.CurrentPageIndex = e.NewPageIndex;
This is one scenario as I explained above...in case page index changed, I am calling the PopulateReportingPeriodTasksGrid() function again and that's when the EditorControl stops working. I've another page, where I am not using "paging", but doing the same as I am doing in the PopulateReportingPeriodTasksGrid procedure. Even in that case, the EditorControl will not work.
Kala
  • 510
    Anyone? Any thoughts?
    In fact, it looks like it's happening on Postback. Am I missing something in restoring the state or something like that? Can you please test the same in a sample application? I tried setting the postback properties to true for the grid but it didn't work!
    Kala
