OK... I have kindof a sepecialised case. I am getting log data back from a DB that has 5 static properties and then any number of variable properties. The class looks like this:
Prop 1, prop 2, prop 3, collection of properties 4-n... all possible properties are known.
Based on the type of log, properties 4-n will be different, again, all possible properties will be known.
The values of these properties will always be text.
binding properties 1-3 are easy... but is it possible to bind column values to items within a sub collection? for example, key="{Binding PropCollection.Prop4}"
Thanks in advance for any help
Marc
IG
any idea whats wrong with my sample or why that Silverlight is throwing that exception that i posted at the top of page 3, (when you click on one of the cells)????
yeah at the moment i am using this and it seems to work
Private Function CreateXamTemplateColumn(ByVal i As Integer, _ ByVal propName As String) As ColumnBase
Dim column As New TemplateColumn()
column.Key = propName & i
column.HeaderText = String.Format("Period#{0}.{1}", i, propName)
column.ItemTemplate = XamlReader.Load(CreateColumnTemplate(i, propName))
column.EditorTemplate = XamlReader.Load(CreateColumnEditTemplate(i, propName)) ' //edit template Return column End Function
Also, generate a unique key for each colum:
column.Key = propName //******* Generate Unqiue key **************// string.format("Column{0}", i); or something like that. Maybe use a random number or somehting, just make it unique.
make sure you are not concatenating anything to the propName parameter. Actually just remove it all together, and replace the {1} in the string.format method with the Hours property. Do this with both the item template and edit template methods.
Private Function CreateColumnEditTemplate(ByVal index As Integer) As String
Dim CellTemp As New StringBuilder() CellTemp.Append("<DataTemplate ") CellTemp.Append("xmlns='http://schemas.microsoft.com/winfx/") CellTemp.Append("2006/xaml/presentation' ") CellTemp.Append("xmlns:x='http://schemas.microsoft.com/winfx/2006/xaml'>") CellTemp.Append([String].Format("<TextBox Text='{{Binding Periods[{0}].Hours, Mode=TwoWay}}' TextAlignment='Right'/>", _ index, propertyName)) CellTemp.Append("</DataTemplate>")
Return CellTemp.ToString() End Function
so i guess based on what you were said earlier about them throwing an error, was it possibly the dup key i error.
i added the index to "hours" to change the key so i would not throw that exception
i changed it back to test, and just exited the loop after one and it seems to work.
anythoughts on how to get around this
ALSO, thanks for all the help!
