There's a showstopper bug that I discovered in the web grid.
I'm binding a custom collection object that implements ICollectionView. The binding works fine and the objects are shown in the grid.
The bug is that if I bind the objects, resize a column and then call Refresh() the grid throws an exception.
I attached a sample solution showing the bug. Run the example. Click on the "Get data" button, then resize a column, then click on the "call refresh" button and see the grid throwing an exception.
PS: is there a way to report bug other than in this forum?
To answer your other question, you can submit bugs and get support through our support request page:
http://ko.infragistics.com/support/submitrequest.aspx
Again, Thanks for the sample, it allowed us to quickly identify and resolve the issue.
-SteveZ
We were able to reproduce the behavior you are describing. I am going to create a support case on your behalf so that you will be notified when this is resolved and the service release is out.
