100
Marker values
Is it possible to add a marker to show the value for each datapoint without showing the shape?
I've tried setting Marker.Type to MarkerType.None but this stops both the Marker shape and value from showing.
  • 26458
    Verified Answer
    You can use a custom marker by supplying a MarkerPointTemplate (marker's type has to be set to Custom) or in this scenario, you can cheat a little and set marker.MarkerSize to 0 and set marker.Fill and marker.Stroke to a transparent brush.
