I can't seem to find this documented anywhere, but I'm working with the WebTree control using the CSOM in a separate javascript file from the web page. I'm using version 2008.3 with Visual Studio 2008. What reference do I need to put at the top of the javascript file to get intellisense. I currently have a reference such as
/// <reference path="C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 3 CLR 2.0\ASP.NET\Scripts\ig_webtree.js"/>
However, I'd prefer not to have the direct path in case another developer has thefile located somewhere else. Does anyone know what the reference would look like using the assembly format? I've tried the following, but it doesn't work.
/// <reference assembly="Infragistics2.WebUI.UltraWebNavigator.v8.3" name="ig_webtree.js"/>
Any assistance would be appreciated.
