245
Parent Item To Sub Menu (Island) Spacing
When a menu is in it's dropped down state, there is a small gap between the top edge of the sub menu (island) and the parent menu item. I want to blend the parent item with the sub menu so I need to close that gap. Can anyone tell me what I need to change? Many TIA.
  • 49378
    Hi smatthews1,
    It has been a while since your post, however in case you still need assistance I would be glad to help.
    There should be no actual space between the menu and the submenus, however such a visual appearance may be caused by the used default border styles and coloring. For your particular implementation I would suggest that you set the BorderColor and BorderStyle properties of the menu as well as the IslandStyle.BorderStyle and IslandStyle.BorderColor properties in order to create a blending feel for your menu.
    Please do not hesitate to contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
    https://ko.infragistics.com/support
