185
DateTimes in X Axis
Is it possible right now or are there any plans in the future to support DateTimes as the "Label" of a DataPoint in a Series in the xamWebChart rather than only allowing a String?  It would be nice then if  the "AutoRange" functionality would work with the raw DateTimes.  I know the Silverlight Toolkit Chart and the Infragistics WinForms Chart support this concept.
Thanks.
  • 27093
    Suggested Answer
    There is such functionality included in our Silverlight Scatter chart. You simply have to place DateTime data in the ValueX type ChartParameter like so:
                     <igChart:Series ChartType="Scatter" >
                        <igChart:Series.DataPoints>
                            <igChart:DataPoint>
                                <igChart:DataPoint.ChartParameters>
                                    <igChart:ChartParameter Type="ValueX" Value="02/02/2000" />
                                    <igChart:ChartParameter Type="ValueY" Value="6" />
                                </igChart:DataPoint.ChartParameters>
                            </igChart:DataPoint>...
    and you can easily set the Minimum and Maximum range properties using a converter or from the code behind like so:
                 xamWebChart1.Axes[0].Minimum = new DateTime(1999, 1, 1).ToOADate();
                xamWebChart1.Axes[0].Maximum = new DateTime(2001, 1, 1).ToOADate();
                double unit = new DateTime(1999, 2, 1).ToOADate() - new DateTime(1999, 1, 1).ToOADate();
                //double unit = new TimeSpan(31 * 3 + 30 * 2 + 28).Ticks;
                xamWebChart1.Axes[0].Unit = unit;
                xamWebChart1.Axes[0].AutoRange = false;
    Hope this makes things clearer.
    Please let me know if I can assist you further on this matter.
    Sincerely,
    Petar Monov,
    DS Engineer,
    Infragistics Bulgaria
