I would like to make the values show up as percents in the pie chart. I can either set it to the value or figure out what percent ahead of time but i want to have the % sign....
Is this possible?
here's some code that will put the % values on there for you...
private void XamWebChart_Loaded(object sender, RoutedEventArgs e) { XamWebChart theChart = (XamWebChart)sender; double total = 0.0; foreach (DataPoint dp in theChart.Series[0].DataPoints) { total += dp.Value; } foreach (DataPoint dp in theChart.Series[0].DataPoints) { dp.Marker = new Marker() { Format = dp.Value / total * 100.0 + "%" }; } }
