I need to set tooltip to cell on Mouse over event in XamWebGrid.
Please can u tell me right way ?
Nandkishor .
Thanks SteveZ ,
It works !!!!
Hi Nandkishor,
This is a feature that we're currently looking to add to the xamWebGrid in a future release. However, until then, you can handle the Grid's CellControlAttached event, and use the ToolTipService attached property to add a tooltip to a cell.
Note: if you take this approach, it is every important, to set the Tooltip to null, for cells you aren't adding a tooltip to, as CellControl's get recycled, which means if you don't clear out the value, it could display a dead value.
void DataGrid1_CellControlAttached(object sender, CellControlAttachedEventArgs e)
if(e.Cell.Column.Key == "Title")
ToolTipService.SetToolTip(e.Cell.Control, e.Cell.Row.Data);
else
ToolTipService.SetToolTip(e.Cell.Control, null);
Hope this helps,
-SteveZ
