235
xamWebChart in TileView databinding
I have been trying to get a webchart I have placed in the UserTemplateMaximized template of a TileView to databind to some numeric properties of the data item being displayed.  How do I bind the datapoints to properties of the object being displayed in the pane?
I also have a DataForm in the UserTemplateMaximized template and was able to bind the current item by setting CurrentItem="{Binding}"
<dataFormToolkit:DataForm x:Name="employeeDetailsForm" Height="400" CurrentItem="{Binding}">          <dataFormToolkit:DataField Label="Vacation Accrual">
               <TextBlock Text="{Binding VacationAccrual}" />
          </dataFormToolkit:DataField>
I thought I could do the same for the bar chart but I am getting xaml parse exception.
xaml:
<DataTemplate x:Key="UserTemplateMaximized">
            <StackPanel>
                <igChart:XamWebChart Name="webChart" Width="300" Height="100" DataContext="{Binding}">
                    <igChart:XamWebChart.Legend>
                        <igChart:Legend Visibility="Collapsed" />
                    </igChart:XamWebChart.Legend>
                    <igChart:XamWebChart.Series>
                        <!--<igChart:SeriesCollection>-->
                            <igChart:Series ChartType="Column" DataPointColor="Different">
                                <igChart:Series.DataPoints>
                                    <igChart:DataPoint Label="Vacation Accrual" Value="{Binding Path=VacationAccrual, Converter={StaticResource DoubleConverter}}" />
                                </igChart:Series.DataPoints>
                            </igChart:Series>
                        <!--</igChart:SeriesCollection>-->
                    </igChart:XamWebChart.Series>
                </igChart:XamWebChart>
Thanks in advance for your help.
  • 30692
    Suggested Answer
    Currently, you can't set properties on individual datapoints with a binding in xamWebChart, so this line is your problem:
    Since DataPoint derives directly from DependencyObect, you can't set bindings on it from Xaml in the current version of Silverlight.
    I've created a sample with a workaround, however, based on what I think you are describing. The gist is that its binding against a collection and using DataMapping even though its just one data point.
    The Xaml:
    <UserControl
        xmlns:dataFormToolkit="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data.DataForm.Toolkit"
        xmlns:data="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data"
        x:Class="SilverlightApplication2.MainPage"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        mc:Ignorable="d" d:DesignWidth="640" d:DesignHeight="480"
        xmlns:igTileView="clr-namespace:Infragistics.Silverlight.Controls;assembly=Infragistics.Silverlight.XamWebTileView.v9.2"
        xmlns:igChart="clr-namespace:Infragistics.Silverlight.Chart;assembly=Infragistics.Silverlight.DataVisualization.Chart.v9.2"
        <UserControl.Resources>
                <StackPanel>
                    <dataFormToolkit:DataForm x:Name="employeeDetailsForm" CurrentItem="{Binding}">
                        <dataFormToolkit:DataForm.ReadOnlyTemplate>
                            <DataTemplate>
                                <StackPanel>
                                    <dataFormToolkit:DataField Label="Name">
                                        <TextBlock Text="{Binding Name}" />
                                </StackPanel>
                            </DataTemplate>
                        </dataFormToolkit:DataForm.ReadOnlyTemplate>
                    </dataFormToolkit:DataForm>
                    <igChart:XamWebChart Name="webChart" Width="300" Height="200">
                            <igChart:Series ChartType="Column" DataPointColor="Different" DataSource="{Binding AsCollection}"
                                            DataMapping="Value = VacationAccrual; Label = VacationAccrualLabel">
                            </igChart:Series>
                </StackPanel>
            </DataTemplate>
            <DataTemplate x:Key="UserTemplateNormal">
                <StackPanel>
                            <DataTemplate>
                                <StackPanel>
                                </StackPanel>
                            </DataTemplate>
                </StackPanel>
            </DataTemplate>
            <DataTemplate x:Key="UserTemplateMinimized">
                <StackPanel Orientation="Horizontal">
                    <TextBlock Text="Name: "/><TextBlock Text="{Binding Name}"/>
                </StackPanel>
            </DataTemplate>
            <DataTemplate x:Key="HeaderTemplate">
            </DataTemplate>
        </UserControl.Resources>
        <Grid x:Name="LayoutRoot">
            <igTileView:XamWebTileView Name="xamWebTileView1"
                                       MaximizedStateChanging="XamWebTileView_MaximizedStateChanging"
                                       ItemsSource="{Binding EmployeeCollection}"
                                       TilePaneContentTemplate="{StaticResource UserTemplateNormal}"
                                       TilePaneHeaderTemplate="{StaticResource HeaderTemplate}"
            </igTileView:XamWebTileView>
        </Grid>
    </UserControl>
    With code behind:
    public partial class MainPage : UserControl
            public MainPage()
                InitializeComponent();
                this.DataContext = this;
            private void ChangeActiveTemplate(string templateName, UIElement element)
                TilePane tile = element as TilePane;
                if (tile != null)
                    tile.ContentTemplate = this.Resources[templateName] as DataTemplate;
            private void SetAllOthersTemplate(string templateName, UIElement element)
                foreach (UIElement child in xamWebTileView1.Items)
                    if (element != child)
                        ChangeActiveTemplate(templateName, child);
            private void XamWebTileView_MaximizedStateChanging(object sender, Infragistics.Silverlight.TileStateChangingEventArgs e)
                TilePane tile = e.Element as TilePane;
                if (tile != null)
                    if (e.NewState == Infragistics.Silverlight.TileState.Maximized)
                        SetAllOthersTemplate("UserTemplateMinimized", e.Element);
                        ChangeActiveTemplate("UserTemplateMaximized", e.Element);
                    else if (e.NewState == Infragistics.Silverlight.TileState.Normal)
                        SetAllOthersTemplate("UserTemplateNormal", e.Element);
                        ChangeActiveTemplate("UserTemplateNormal", e.Element);
                    else
                        ChangeActiveTemplate("UserTemplateMinimized", e.Element);
            private EmployeeCollectionViewModel _employeeCollection;
            public EmployeeCollectionViewModel EmployeeCollection
                get
                    if (_employeeCollection == null)
                        _employeeCollection = new EmployeeCollectionViewModel();
      //test data
                        _employeeCollection.Add(new EmployeeViewModel() { Name = "Bob", VacationAccrual = 10 });
                        _employeeCollection.Add(new EmployeeViewModel() { Name = "Jessie", VacationAccrual = 10 });
                        _employeeCollection.Add(new EmployeeViewModel() { Name = "Jill", VacationAccrual = 4 });
                        _employeeCollection.Add(new EmployeeViewModel() { Name = "James", VacationAccrual = 13 });
                        _employeeCollection.Add(new EmployeeViewModel() { Name = "Brian", VacationAccrual = 20 });
                    return _employeeCollection;
        public class EmployeeCollectionViewModel : ObservableCollection<EmployeeViewModel>, INotifyPropertyChanged
            public EmployeeCollectionViewModel()
        public class EmployeeViewModel
            public string Name { get; set; }
            public double VacationAccrual { get; set; }
            public string VacationAccrualLabel { get { return "VacationAccrual"; } }
            public IEnumerable AsCollection
                get
                    return new List<EmployeeViewModel>() { this };
    In particular, I'm not certain what you intended the UserTemplateMaximized for, from the information you provided, so I made an educated guess. Does this help?
    -Graham
  • 28496
    what are the exception details?
    do you have a sample project you could send?  i'm not familiar with your setup using a DataField, so i'm uncertain how to reproduce the problem.
