50
Delete Row from Ultrawebgrid
I figured out how to do the auto postback doing an edit but I cannot get the DeleteRow process to work without requiring another rowselection.  I have added the code from the Samples:
function removeRow() {
var activeRow = igtbl_getGridById(_clientGridID).getActiveRow();
if (activeRow != null)
activeRow.deleteRow();
activeRow.endEditRow();
And then added the necessary items to my code-behind.  I initialize my UpdateRow event and then add the necessary code to update the database.  The problem is the event does not get fired until I select another row.  With the update all I had to do was call the activeRow.processUpdateRow() from javascript and it would fire immediately.  I read othe posts about this and the person talks about just using the UpdateRow process.  That means I will have to have a Delete mechanism in my RowEditTemplate which I don't want.  Either that or I am missing the one piece that will have that statement make sense.
What am I missing?
