1. Again i report "the same" issue as i reported in 2009.1. Now when the Summary Icon is introduced the space set aside to this icon will "overwrite" the text thats in the header. At least when you also have the pinning icon next to it. The pinning icon did this in 2009.1 and this was reported and fixed. Seems we might have to report this for every "icon" that is introduced in the header. ;)
2. On the last column in a grid (the column that fills out the "rest" of the space to the right in the grid) , if summary is turned on and you click the summary icon, the appearing list is partly "outside" the area of the grid making it unusable. The placement makes it only partly visible. (Right half of the list is "outside" the right edge of my monitor).
Oh btw ...Thumbs up for the summary line functionality. At first glance its awsome .. :)
regards
Øyvind
In regards to issue #1. This should be resolved in the first Service Release for 9.2. The earlier report came in after our code freeze, so the modifications could not be incorporated at the time.
As for issue # 2, we will work on resolving this issue.
Thank you for the reports.
