770
Scroll bar hiding
hi,
  we are using XamWebGrid .
 I have to hide visibility of scrollbar .
 I have declared property
ScrollViewer.VerticalScrollBarVisibility
="Hidden"
but then also it vertical bar .
how can I do that
Thanks ,
Nandkishor .
  • 40030
    Suggested Answer
    Hi Nandkishor,
    The xamWebGrid doesn't support the ScrollViewer's attached properties.  Although i suppose its something we can look into.
    However, in order to achieve this you have 2 options.
    1.  If you don't want to be able to scroll, you can put the grid in a container that gives it infinite height.  Such as a Vertical StackPanel.
    2.  Modify the ControlTemplate of the xamWebGrid and change it's vertical scrollbar's Visibility.
    -SteveZ
