2589
Cannot set DateTime value in DateColumn to null
This is a class I use to display on grid:
public class Person :INotifyPropertyChanged
        public event PropertyChangedEventHandler PropertyChanged;
        private void NotifyPropertyChanged(String info)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(info));
        private string _company;
        private DateTime? _date;
        public int ID { get; set; }
        public string Company
            get { return _company; }
            set {
                if (string.IsNullOrEmpty(value))
                    throw new Exception("Company must not be empty");
                _company = value;
                NotifyPropertyChanged("Company");
        public DateTime? Date
            get { return _date; }
            set
                _date = value;
                NotifyPropertyChanged("Date");
        public string Name { get; set; }
        public KeyValue Field { get; set; }
        public Person(int id, string name, string comp, DateTime date, KeyValue field)
            ID = id;
            Name = name;
            Company = comp;
            Date = date;
            Field = field;
        public Person()
And this is a part of XAML  which displays Date property:
<igGrid:TemplateColumn Key="Date">
                    <igGrid:TemplateColumn.HeaderTemplate>
                        <DataTemplate>
                            <TextBlock Text="Date" />
                        </DataTemplate>
                    </igGrid:TemplateColumn.HeaderTemplate>
                    <igGrid:TemplateColumn.ItemTemplate>
                        <DataTemplate>
                            <TextBlock Text="{Binding Date}"/>
                        </DataTemplate>
                    </igGrid:TemplateColumn.ItemTemplate>
                    <igGrid:TemplateColumn.EditorTemplate>
                        <DataTemplate>
                            <controls:DatePicker Text="{Binding Date, Mode=TwoWay}" />
                        </DataTemplate>
                    </igGrid:TemplateColumn.EditorTemplate>
                </igGrid:TemplateColumn>
Each time I enter edit mode and clear date value, and then move cursor to next row or cell, Date cell won't become empty and empty date won't save to datasource. What is the problem?
BTW the same thing happens when I'm using DateColumn.
Thank you.
  • 21382
    Suggested Answer
    Using the Date Column I was not able to reproduce your results,
    <iggrid:XamWebGrid x:Name="grid">
    </iggrid:XamWebGrid>
          public class Person : INotifyPropertyChanged
                private DateTime? _dob;
                public int Age { get; set; }
                public DateTime? DOB
                      get
                            return this._dob;
                      set
                            if (this._dob != value)
                                  this._dob = value;
                #region INotifyPropertyChanged Members
                #endregion
                public MainPage()
                      InitializeComponent();
                      this.grid.EditingSettings.AllowEditing = EditingType.Cell;
                      ObservableCollection<Person> p = new ObservableCollection<Person>();
                      p.Add(new Person() { Name = "bob", Age = 2, DOB= DateTime.Now });
                      this.grid.ItemsSource = p;
    Using the TemplateColumn I was able to reproduce you behavior, but that is because of a quirk in the DatePicker control.  The DatePicker doesn't finalize until after the blur on the control is called by the framework when entering text.  By this time the binding has already been called to update.
    This was one of the reasons why we created a Date Column.
    Since I am able to null out the text of a DateColumn, could you provide either a sample or explicit steps to reproduce your issue?
