1220
column moving
hello,
i am trying to re-order columns in the grid. basically i support personalization scheme where each user can select the order of columns they would like to see.
on postback, as users elect different column order, the grid is initially loaded, and in a later event it attempts to be re-ordered as per user preferences.
i tried using Remove(col) Add(col) to change the order, as well as Move(col). both move only the header, but data in the rows stays the same. meaning the move only swaps grid header cells.
