65
WebGrid - igtbl_initGrid error after converting from 1.1 application
I was recently given a 1.1 project to convert to 2.0 and I am encountering an error I'm hoping you can shed some light on.  The 1.1 application used NetAdvantage 2003 Vol2 and the 2.0 application is using NetAdvantage for .NET 2007 Volume 1 CLR 2.0.
I have a form with a serverside button and in its ServerClick event writes back some JavaScript that will call a display() function.  The display function calls the igtbl_initGrid, passing in the name of my grid.
The code looks like 'var grid = igtbl_initGrid(<name of my grid>);
The line that fails is line 251 of ig_WebGrid_dom.js with an 'Object required' error.  Checking the previous line, it seems that _scrElem is null and that this.Element.parentNode.previousSibling has no value.
I have isolated all of the code into one test page that duplicates the error.
John
Here is the contents of TestWebGrid.aspx and .aspx.vb file:
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="TestWebGrid.aspx.vb" Inherits="OCWCVC.TestWebGrid" EnableEventValidation="false" %>
<%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v7.1, Version=7.1.20071.40, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
    <title>Untitled Page</title>
     <script type="text/javascript" src="test.js">
   </script>
</head>
<body>
    <form id="form1" runat="server">
    <igtbl:UltraWebGrid ID="ugrdReferralsSelected" runat="server" Width="333px" Height="230px" DisplayLayout-JavaScriptFileName="" DisplayLayout-JavaScriptFileNameCommon="">
                <Bands>
                    <igtbl:UltraGridBand>
                    </igtbl:UltraGridBand>
                </Bands>
                <DisplayLayout AllowDeleteDefault="Yes" AllowAddNewDefault="Yes" RowHeightDefault="20px"
                    ScrollBar="Never" CellSpacingDefault="-1" CellPaddingDefault="-1"
                    RowSelectorsDefault="No" Name="ugrdReferralsSelected" AllowUpdateDefault="Yes">
                    <AddNewBox ButtonStyle-BorderWidth="1px" ButtonStyle-BorderStyle="Solid" ButtonStyle-BackColor="lightgray">
                    </AddNewBox>
                    <Pager ComboStyle-BorderStyle="Solid" ComboStyle-BorderWidth="1px" ComboStyle-BackColor="LightGray">
                    </Pager>
                    <HeaderStyleDefault CssClass="GridHeader" >
                        <BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails>
                    </HeaderStyleDefault>
                    <FrameStyle Width="333px" BorderWidth="1px" Font-Size="8pt" Font-Names="Verdana"
                        BorderColor="#6F8FB5" BorderStyle="Solid" Height="230px">
                    </FrameStyle>
                    <FooterStyleDefault BorderWidth="1px" BorderStyle="Solid" BackColor="LightGray">
                    </FooterStyleDefault>
                    <ClientSideEvents CellChangeHandler="addDrtoList" AfterExitEditModeHandler="addDrtoList">
                    </ClientSideEvents>
                    <ActivationObject BorderStyle="None" BorderColor="231, 239, 255">
                    </ActivationObject>
                    <EditCellStyleDefault Cursor="Hand" BorderWidth="0px" BorderStyle="None">
                    </EditCellStyleDefault>
                    <SelectedRowStyleDefault BackColor="Silver">
                    </SelectedRowStyleDefault>
                    <RowStyleDefault BorderWidth="1px" BorderColor="Gray" BorderStyle="Solid" HorizontalAlign="Left">
                        <Padding Left="3px"></Padding>
                        <BorderDetails WidthLeft="0px" WidthTop="0px"></BorderDetails>
                    </RowStyleDefault>
                </DisplayLayout>
            </igtbl:UltraWebGrid><br />
        <br />
        <asp:Button  ID="btnDone" runat="server" Text="Done" />
        </form>
</body>
</html>
Public Partial Class TestWebGrid
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Me.ugrdReferralsSelected.Font.Size = New FontUnit(8)
        Me.ugrdReferralsSelected.Columns.Add("col0", "c")
        Me.ugrdReferralsSelected.Columns.Add("col1", "r")
        Me.ugrdReferralsSelected.Columns.Add("col2", "d")
        Me.ugrdReferralsSelected.Columns.Add("col3", "rd")
        Me.ugrdReferralsSelected.Columns.Add("col4", "sd")
        Me.ugrdReferralsSelected.Columns.FromKey("col0").Width = New Unit(20)
        Me.ugrdReferralsSelected.Columns.FromKey("col0").HeaderText = "c"
        Me.ugrdReferralsSelected.Columns.FromKey("col0").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.No
        Me.ugrdReferralsSelected.Columns.FromKey("col1").Width = New Unit(20)
        Me.ugrdReferralsSelected.Columns.FromKey("col1").HeaderText = "r"
        Me.ugrdReferralsSelected.Columns.FromKey("col1").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.No
        Me.ugrdReferralsSelected.Columns.FromKey("col2").Width = New Unit(60)
        Me.ugrdReferralsSelected.Columns.FromKey("col2").HeaderText = "d"
        Me.ugrdReferralsSelected.Columns.FromKey("col2").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.No
        Me.ugrdReferralsSelected.Columns.FromKey("col3").Width = New Unit(200)
        Me.ugrdReferralsSelected.Columns.FromKey("col3").HeaderText = "dr"
        Me.ugrdReferralsSelected.Columns.FromKey("col3").FieldLen = 25
        Me.ugrdReferralsSelected.Columns.FromKey("col4").Width = New Unit(9)
        Me.ugrdReferralsSelected.Columns.FromKey("col4").HeaderText = ""
        Me.ugrdReferralsSelected.Columns.FromKey("col4").AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.No
        Me.ugrdReferralsSelected.DisplayLayout.CellClickActionDefault = Infragistics.WebUI.UltraWebGrid.CellClickAction.CellSelect
        Me.ugrdReferralsSelected.DisplayLayout.AllowUpdateDefault = Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes
        Me.ugrdReferralsSelected.DisplayLayout.AllowAddNewDefault = Infragistics.WebUI.UltraWebGrid.AllowAddNew.Yes
        Me.ugrdReferralsSelected.DisplayLayout.AddNewBox.Hidden = False
        Me.ugrdReferralsSelected.DisplayLayout.AddNewBox.Style.CustomRules = "display:none"
    End Sub
    Protected Sub btnDone_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnDone.Click
        Me.ClientScript.RegisterStartupScript(GetType(Page), "Display", "<script language='javascript'>  DisplayAfterError();</script>")
    End Sub
End Class
