20
Binding Ultrawebtab
Hi Guys,
Anyidea how i can bind the ultrawebtab to typed dataset?
There doesn't seem to be DatasourceId property.
Regards
Salim
  • 5118
    Hello Salim,
    The UltraWebTab does not support binding in that aspect.  I am assuming you want to build the tabs from a list?  To do that you just cruise through your list (dataset/array/collection/object) and create the tab objects dynamically.
     What else should the control do for this case?
     What are the expected results if you could set a DataSource/DataSourceId for the UltraWebTab control?
