175
Client Side Value List
I want to populate Value List from Javascript. I had already put the post regarding the similar issue. and I got reply from Infragistics also. They gave me the following list. http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2906
It solved my problem a little.
Now I have one more problem.
I want to populate the number of items in the Value List from Client / JS based on some condition. I am able to get the values from Server using AJAX call but it is not getting displayed in the Value List.
Server Code:
Class create_support_roster:
 [AjaxPro.AjaxMethod()]
    public string[][] jagged()
        string[][] obj = new string[2][];
        obj[0] = new string[63];
        obj[1] = new string[2];
        DataSet ds1 = new DataSet();
        Swap m_swapClass = new Swap();
        m_swapClass.FillShift(ds1);
        obj[0][0] = "OFF";
        obj[0][1] = "HL";
        for (int i = 0; i < ds1.Tables[0].Rows.Count; i++)
            obj[0][i + 2] = ds1.Tables[0].Rows[i]["shift"].ToString();
        obj[1][0] = "PL";
        obj[1][1] = "OFF";
        return obj;
Note: 1. I am getting 60 rows from DB
           2. obj has all the values from ds1
Client Code/ JS:
function grdRegularRoster_BeforeEnterEditModeHandler(gridName, cellId)
    var col = igtbl_getColumnById(cellId);
    var cell = igtbl_getCellById(cellId);
    var vlist = new Array(2);
    var v = create_support_roster.jagged().value;
    if (cell.getValue() == "PL")
        vlist[0] = v[0];
        vlist[1] = v[1];
        col.ValueList = vlist;
Note: vlist variable contains all the values sent from server i.e. 60 items (it properly shows length = 60)
           Even the data it sent is also correct. I checked it thru alert().
But the when executed <col.ValueList = vlist;> I am getting "undefined" 60 times i.e. 60 Value List items as "undefined". I tried all the combition viz.
1.         col.ValueList = vlist[0];
2.         col.ValueList = vlist[1];
3.         col.ValueList = vlist[0][0];
4.         col.ValueList = vlist[0][1];
5.         col.ValueList = vlist[1][0];
6.         col.ValueList = vlist[1][1];
7.         col.ValueList = v;
and many more......
Not getting expected result...please help!
Thanks & Regards,
Anuj D.Vaijapurkar.
